[Qgis-user] ID field does not show up
Andre Joost andre+joost at nurfuerspam.de
Sun Aug 19 03:35:44 PDT 2012
Am 19.08.2012 10:24, schrieb Julian Bogdani:
> Hi, it's not a spatialite db I want to add to my project, but a
> simple text table. I need to load external attributes from plain text
> tables and join with my vector layers.
Yes, I understood that. But you can store those simple tables in your
sqlite database as well, together with the vector layers. The database
can hold as much tables as you want, having only text or vectors. And
Add sqlite database table will show all fields.
> I think that the missing
> ID field should be considered a bug, because we should be able to
> manage external data as they are, without filters.
You can open a ticket for it. Maybe the programmer thought it was a good
idea to hide the id. What will happen if you edit the id field, and the
value is not unique anymore? Or add another object?
Greetings,
André Joost
