[Qgis-user] hide border-triangle in the desktop
Goyo goyodiaz at gmail.com
Wed Jul 4 11:31:14 PDT 2012
2012/7/4 Jan Tappenbeck <osm at tappenbeck.net>:
> Hi!
> i have transform rasterimage by gdal to an other coord-system. now i load
> the rasterimages into qgis and the black-border-triangle overlayer
> informations in other images.
> the border-triangle are with alpha-information and the mapserver option
> OFFSITE 251 250 249 allow to make the border-triangle transparency.
> is it possible to make this even in qgis?
I can make corners transparent in single band rasters reprojected on
the fly this way: go to "Layer properties", "Transparency" tab, in the
"Transparent pixel list" create a new entry, then set the "Gray"
column to the "No data value" shown in the upper right.
Hope this helps.
Goyo
