[Qgis-user] Qgis Sextante plugin trouble
    Aitor Bastarrica Izaguirre
    aitor.bastarrika at ehu.es
    Wed Jul 18 01:49:43 PDT 2012
Dear Qgis users,
I am working with a DTM raster file. I have a region extent/resolution
set in the Sextante configuration panel and the "Use min covering
region" unchecked.
I use the Sextante's r.slope function and result is ok, as the result
is clipped to the region extents with the required spatial resolution.
Now I would like to clip the original DTM with the same region
extent/resolution. I have tried the r.mapcalculator function, with a
simple mathematical function (A*1) in order to obtain the same
original DTM clipped and resampled to the region extent/resolution.
The programm shows an error and the output file is not created.
I obtain the next error in the sextante_qgis.log file
ALGORITHM|Wed Jul 18 2012
10:21:00|Sextante.runalg("grass:r.mapcalculator","C:/temp/lidar/MDT_037_1_8.asc","C:/temp/lidar/MDT_037_1_8.asc","C:/temp/lidar/MDT_037_1_8.asc","C:/temp/lidar/MDT_037_1_8.asc","C:/temp/lidar/MDT_037_1_8.asc","C:/temp/lidar/MDT_037_1_8.asc","A*1",None)
INFO|Wed Jul 18 2012 10:21:00|GRASS execution commands|g.region
n=4799224.59978 s=4798356.20966 e=488133.737978 w=487533.468315
res=10.0|r.in.gdal input="C:/temp/lidar/MDT_037_1_8.asc" band=1
out=tmp13425996604435 --overwrite -o|r.in.gdal
input="C:/temp/lidar/MDT_037_1_8.asc" band=1 out=tmp13425996604436
--overwrite -o|r.in.gdal input="C:/temp/lidar/MDT_037_1_8.asc" band=1
out=tmp13425996604437 --overwrite -o|r.in.gdal
input="C:/temp/lidar/MDT_037_1_8.asc" band=1 out=tmp13425996604438
out=tmp13425996604439 --overwrite -o|r.in.gdal
input="C:/temp/lidar/MDT_037_1_8.asc" band=1 out=tmp13425996604440
--overwrite -o|r.mapcalculator amap=tmp13425996604440
bmap=tmp13425996604440 cmap=tmp13425996604440 dmap=tmp13425996604440
emap=tmp13425996604440 fmap=tmp13425996604440 formula=A*1
outfile=outfile --overwrite|g.region rast=outfile|r.out.gdal -c
createopt="TFW=YES,COMPRESS=LZW" input=outfile output="C:\Documents
and Settings\Aitor\sextante\tempdata\grassrmapcalculator33.tif"
ERROR|Wed Jul 18 2012 10:21:56|'ascii' codec can't decode byte 0xf3 in
position 6142: ordinal not in range(128)|Traceback (most recent call
last):|  File "C:/Documents and
Settings/Aitor/.qgis/python/plugins\sextante\core\GeoAlgorithm.py",
line 116, in execute|    self.processAlgorithm(progress)|  File
"C:/Documents and
Settings/Aitor/.qgis/python/plugins\sextante\grass\GrassAlgorithm.py",
line 258, in processAlgorithm|    GrassUtils.executeGrass(commands,
progress);|  File "C:/Documents and
Settings/Aitor/.qgis/python/plugins\sextante\grass\GrassUtils.py",
line 260, in executeGrass|
SextanteLog.addToLog(SextanteLog.LOG_INFO, loglines)|  File
"C:/Documents and
Settings/Aitor/.qgis/python/plugins\sextante\core\SextanteLog.py",
line 33, in addToLog|    text = unicode(a)|UnicodeDecodeError: 'ascii'
codec can't decode byte 0xf3 in position 6142: ordinal not in
range(128)|
My configuration:
Windows XP
Qgis 1.7.4
Sextante 1.0.7
I could do it in GRASS, but I would like to use the Sextante plugin
that I find more integrated with Qgis.
All suggestions are welcome,
Best regards
Aitor
