[Qgis-user] Marker line not shown using New Symbology
Goyo goyodiaz at gmail.com
Fri Nov 2 15:06:58 PDT 2012
2012/11/1 magerlin <MAP at ramboll.dk>:
> I am trying to use a line symbology with arrow heads in both ends:
> <http://osgeo-org.1560.n6.nabble.com/file/n5013418/Marker_line_not_shown.png>
> But the arrow head which should be shown on last vertex point is not shown
> on the map canvas!
I can replicate this in master but I think it's due to duplication of
the last vertex. Newly digitized lines look right.
Goyo
> The problem occurs both in windows and in Linux.
> One peculiar thing is that the dimension plugin uses a symbology with two
> arrowheads like I wish to use and it works perfect. But using the same
> symbology (*.qml file) on my own shape file gives the same errors as above.
> And if I manually ad lines to the dimension plugin layer some of my added
> lines (without numbers) are with errors while the others are ok:
> <http://osgeo-org.1560.n6.nabble.com/file/n5013418/Dimension_Plugin_Symbology.png>
> You can test my shape file (including qml) file here:  double_arrows.zip
> <https://dl.dropbox.com/u/8189384/double_arrows.zip>
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Marker-line-not-shown-using-New-Symbology-tp5013418.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
