[Qgis-user] Python error enabling sextante plugin
Matteo Ghetta matteo.ghetta at gmail.com
Fri Nov 9 01:18:46 PST 2012
Hi guys,
i have almost the same problem with sextante and python (qgis 1.9 on
ubuntu).
I started qgis as usually and qgis gave me the python error above
described.
So I tried to uninstall sextante, re-install it, and move directories (from
/usr/share/qgis/python/plugins and from /.qgis) and replace them.
What now happens is that, running qgis I have this error:
SEXTANTE
The Plugin Installer has detected an obsolete plugin which masks a newer
version shipped with this QGIS version. This is likely due to files
associated with a previous installation of QGIS. Please use the Plugin
Installer to remove that older plugin in order to unmask the newer version
shipped with this copy of QGIS.
Sextante and qgis work without problems, but I don't understand I I should
do something to solve this little problem.
Thanks
2012/11/9 Andre Joost <andre+joost at nurfuerspam.de>
> Am 09.11.12 08:27, schrieb Andrea Peri:
>> today I had tried to updat the osgeo4w installation of qgs-dev.
>> After this. The python error is still here.
>> SO I try to remove the sextante plugin. The plugin install will do me only
>> the downgrade option. The installer say me that I have the 1.0.8 and the
>> downgrade will bring me to the 1.0.7 version.
>> I give a yes to downgrading.
>> But with my big surprise it say me that is not possible to install
>> because is missing a dependencies.
> I ran into the same problems. But after restarting Qgis worked, and had
> Sextante Menu entries. I think 1.0.7 is the last non-core-plugin version,
> which installes to \.qgis\python plugins.
> If you don't need the broken core sextante, you can delete the folder from
> C:\OSGeo4W\apps\qgis-dev\**python\plugins. Or wait till next week ;-)
> HTH,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121109/06cf2b94/attachment.html>
