[Qgis-user] qgis and Large Format Print
Ramon AndiƱach custard at westnet.com.au
Fri Nov 23 01:35:34 PST 2012
On 23/11/2012, at 11:42, Ramon AndiƱach <custard at westnet.com.au> wrote:
> I've just worked through your notes on my OSGeo4w master - 3700d84 (unfortunately not a fresh install, might try later) and actually had crashes where you did.
> I did not get any blank PDFs though.
The test above was with win7. On this machine I have both qgis *and* qgis-dev.
I did a clean qgis-dev *only* install on winXP and got the crashes *and* the blank PDFs.
I then backed up my win7 install (which is remarkably easy) and then did a qgis-dev only install and got the same results.
So blank PDFs is confirmed to me.
I then restored my old qgis and qgis-dev and went looking at packages.
If I add python-shapely on the XP machine I get crashes but not blank PDFs. Is any one able to confirm that?
I'm out of time now to test it on win7.
See how I go on the weekend.
-ramon.
