[Qgis-user] Error installing Qgis-dev using OSGEO4w
Andre Joost andre+joost at nurfuerspam.de
Fri Oct 26 04:09:07 PDT 2012
Am 26.10.12 12:55, schrieb PIERRE Sylvain:
> I got already the same but with Windows 7 and the message is Not
> possible to find procedure entry point ?GEOPROJ4@@3VQString@@B in the
> qgis_core.dll dynamic library Your solution fails.
Looks like the qgis_core.dll is making trouble. If you have both Lisboa
and master on your computer,
You should have to versions, one 4,6 MB and one 5.5 MB large.
It depends on the path variable, which one is taken. In your case it
seems to be the wrong one.
What happens if you rename the older one?
HTH,
André Joost
