[Qgis-user] Error installing Qgis-dev using OSGEO4w
Andre Joost
andre+joost at nurfuerspam.de
Fri Oct 26 04:16:38 PDT 2012
Am 26.10.12 13:09, schrieb Andre Joost:
> Am 26.10.12 12:55, schrieb PIERRE Sylvain:
>> I got already the same but with Windows 7 and the message is Not
>> possible to find procedure entry point ?GEOPROJ4@@3VQString@@B in the
>> qgis_core.dll dynamic library Your solution fails.
> Looks like the qgis_core.dll is making trouble. If you have both Lisboa
> and master on your computer,
> You should have to versions, one 4,6 MB and one 5.5 MB large.
> It depends on the path variable, which one is taken. In your case it
> seems to be the wrong one.
> What happens if you rename the older one?
By the way, did you start qgis-dev.bat or qgis-dev.exe?
The .bat sets the environmnet variable correctly before starting the exe.
Greetings,
André Joost
