[Qgis-user] Error installing Qgis-dev using OSGEO4w
Alexandre Neto
senhor.neto at gmail.com
Fri Oct 26 07:30:54 PDT 2012
I had already both QGIS Master (1.9.0) and Qgis Stable (1.8.0) working on
my windows desktop.
I believe the problem started when the gdal Library was updated from
1.9.1-2 to 1.9.2-1. From that moment on, Qgis started to crash while
opening Mr.Sid Files.
For that reason I had to downgrade gdal back to 1.9.1-2. QGIS 1.8.0 works
well, but 1.9.0 become impossible to install\upgrade.
I already tried to fully reinstall the all OSGEO, with no sucess.
Alexandre Neto
On Fri, Oct 26, 2012 at 12:16 PM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Am 26.10.12 13:09, schrieb Andre Joost:
> Am 26.10.12 12:55, schrieb PIERRE Sylvain:
>>> I got already the same but with Windows 7 and the message is Not
>>> possible to find procedure entry point ?GEOPROJ4@@3VQString@@B in the
>>> qgis_core.dll dynamic library Your solution fails.
>> Looks like the qgis_core.dll is making trouble. If you have both Lisboa
>> and master on your computer,
>> You should have to versions, one 4,6 MB and one 5.5 MB large.
>> It depends on the path variable, which one is taken. In your case it
>> seems to be the wrong one.
>> What happens if you rename the older one?
> By the way, did you start qgis-dev.bat or qgis-dev.exe?
> The .bat sets the environmnet variable correctly before starting the exe.
> Greetings,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121026/0da105b8/attachment.html>
