[Qgis-user] Display of Contour Map
Zoltan Szecsei zoltans at geograph.co.za
Sun Sep 2 03:11:28 PDT 2012
Press F1  or go to http://www.qgis.org/en/documentation.html
On 2012/09/01 01:39, Federico Nadela wrote:
> I  now have the .shp file of the contour map on the Layers
> (left) sideboard. How do I go about displaying the contour map? I
> noticed that when I clicked on the .shp file that there are many Layer
> Properties to be filled in. What would be the parameters be to display
> a contour map?
> Federico M. Nadela
> *From:* Zoltan Szecsei <zoltans at geograph.co.za>
> *To:* Federico M Nadela <fmnadela at yahoo.com>
> *Cc:* qgis-user at lists.osgeo.org
> *Sent:* Friday, August 31, 2012 7:17 PM
> *Subject:* Re: [Qgis-user] QGIS Contour Generation
> Hi Federico,
> Please email the list, and not the person directly.
> The purpose of lists is to pool knowledge, not to give courses, so all
> conversations relevant to the list should stay with the list.
> Judging by your unfamiliarity with raster and vector data formats, it
> seems like you need deeper knowledge about what you are doing, rather
> than just assistance with the use of QGis.
> I don't have any URLs I can suggest for this, but perhaps someone else
> on this list can help.
> Kind regards,
> Zoltan
> On 2012/08/31 12:29, Federico M Nadela wrote:
>> Dear Zoltan,
>> Many thanks for your prompt reply. I have not used shape file before
>> so you have to walk me through. My DSM is in .tiff format. Can I use
>> that instead of .shp?
>> Please give me a sample of an acceptable output file. Thanks!
>> Federico
>> Sent from my iPhone
>> On Aug 31, 2012, at 14:47, Zoltan Szecsei <zoltans at geograph.co.za
>> <mailto:zoltans at geograph.co.za>> wrote:
>>> On 2012/08/31 08:36, Federico Nadela wrote:
>>>> I have reached as far as the Contour tab but unable to specify an
>>>> acceptable output file path in the *Output file for contour
>>>> lines(vector*). I tried to input _C:/User/Fritz/Documents/Temp.shp_
>>>> but got an error message that says it is not a directory. I tried
>>>> other paths but they were all unacceptable. Please advise. Thanks!
>>>> Federico M. nadela
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Yep, true - if your 'Temp.shp' is not a DIRECTORY within your
>>> documents folder.
>>> What you and I call "shapefiles" is actually a group of 3 or more
>>> files that are needed by ESRI and other GIS products that use
>>> 'shapefile format'
>>> For this reason you must specify the name of an existing directory,
>>> and not a filename that you want to create.
>>> Are you sure the "other paths" you tried existed and were actually
>>> directory names?
>>> HTH,
>>> Zoltan
>>> Zoltan Szecsei PrGISc [PGP0031]
>>> Geograph (Pty) Ltd.
>>> P.O. Box 7, Muizenberg 7950, South Africa.
>>> 65 Main Road, Muizenberg 7945
>>> Western Cape, South Africa.
>>> 34° 6'16.35"S 18°28'5.62"E
>>> Tel: +27-21-7884897  Mobile: +27-83-6004028
>>> Fax: +27-86-6115323http://www.geograph.co.za/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120902/0fb73229/attachment.html>
