[Qgis-user] Python-gdal missing
Agustin Lobo
alobolistas at gmail.com
Tue Sep 4 05:12:51 PDT 2012
Luis,
Just got the same problem, it's so confusing. I do not have
/usr/local/lib/libgdal.so.1 -> libgdal.so.1.15.1.old
I do have
libgdal.so -> libgdal.so.1.16.1
libgdal.so.1 -> libgdal.so.1.16.1
so this is probably not the problem.
Etienne, why you mention gdal-1.7.3 ? I'm using libgdal-1.9.1-2
and the ubuntugis-unstable repository.
Agus
On Fri, Aug 31, 2012 at 2:19 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Luis,
> which repositories are you using? gdal-1.7.3 is very old, consider
> using the ubuntugis-unstable repositories (and remove the qgis.org
> repository if you're using that one).
> I find it puzzling that you have files installed in /usr/local -
> because packages from either ubuntu the ubuntugis ppa should not
> install there.
> Etienne
> On Fri, Aug 31, 2012 at 3:36 AM, Luís de Sousa
> <luis.a.de.sousa at gmail.com> wrote:
>> Dear all,
>> I ran apt-get upgrade yesterday and the libgdal files were again installed
>> in /usr/local/lib/ prompting once more the error at start up.
>> Is there any way to solve this permanently?
>> Thank you,
>> Luís
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Python-gdal-missing-tp4982586p4998972.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
