[Qgis-user] Python-gdal missing
Etienne Tourigny
etourigny.dev at gmail.com
Tue Sep 4 05:57:11 PDT 2012
On Tue, Sep 4, 2012 at 9:12 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Luis,
> Just got the same problem, it's so confusing. I do not have
> /usr/local/lib/libgdal.so.1 -> libgdal.so.1.15.1.old
> I do have
> libgdal.so -> libgdal.so.1.16.1
> libgdal.so.1 -> libgdal.so.1.16.1
> so this is probably not the problem.
> Etienne, why you mention gdal-1.7.3 ? I'm using libgdal-1.9.1-2
> and the ubuntugis-unstable repository.
Luis mentioned that version earlier
> Agus
> On Fri, Aug 31, 2012 at 2:19 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Luis,
>> which repositories are you using? gdal-1.7.3 is very old, consider
>> using the ubuntugis-unstable repositories (and remove the qgis.org
>> repository if you're using that one).
>> I find it puzzling that you have files installed in /usr/local -
>> because packages from either ubuntu the ubuntugis ppa should not
>> install there.
>> Etienne
>> On Fri, Aug 31, 2012 at 3:36 AM, Luís de Sousa
>> <luis.a.de.sousa at gmail.com> wrote:
>>> Dear all,
>>> I ran apt-get upgrade yesterday and the libgdal files were again installed
>>> in /usr/local/lib/ prompting once more the error at start up.
>>> Is there any way to solve this permanently?
>>> Thank you,
>>> Luís
>>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Python-gdal-missing-tp4982586p4998972.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
