[Qgis-user] Rasterlite datasource gets always absolute path
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Tue Sep 4 05:32:24 PDT 2012
If I save a project with Spatialite vectors and Rasterlite rasters by using the
setting for relative paths, the Spatilite datasource will be like
<datasource>dbname='./vectors.sqlite' table="test" (GEOMETRY) sql=</datasource>
However, the Rasterlite source gets saved as
<datasource>RASTERLITE:D:/data/raster.sqlite,table=rastertest</datasource>
This means that rasters are not found if my USB disk gets another drive letter.
I made a little test and it seems that Rasterlite datasource can use relative
paths in a similar way than Spatialite datasource and the following
configuration works for me:
<datasource>RASTERLITE:./rasters.sqlite,table=rastertest</datasource>
Regards,
-Jukka Rahkonen-
