[Qgis-user] Starting QGIS
Eliana Acosta Valero
eliana.acosta at igac.gov.co
Mon Sep 24 13:13:45 PDT 2012
Thanks....!!
I've found the plugin and I'm trying to work with this, but what I exactly have to do is to construct polygons with lines, and the way to create those lines is with specific lengths and circles intersections... I don't know if you have ever work with "Distance Tool" of ArcGIS. There, I have two lines and I can close the polygon finding the intersection between two circles of an specific radio, something like this:
_________
| 10 mts
|- 6 mts -x
Where, "x" represents the point where a distance of 10 mts and 6 mts intersects...
Do you know if QGIS has some plugin who can do something like that?....
I really appreciate your help!
Eliana.
-----Mensaje original-----
De: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] En nombre de Bernd Vogelgesang
Enviado el: lunes, 24 de septiembre de 2012 02:46 p.m.
Para: qgis-user at lists.osgeo.org
Asunto: Re: [Qgis-user] Starting QGIS
Am 24.09.2012, 17:57 Uhr, schrieb Paolo Cavallini <cavallini at faunalia.it>:
> Il 24/09/2012 17:49, Eliana Acosta Valero ha scritto:
>> Hi! At first I'm sorry beocouse of my bad english, I'm from Colombia
>> and I don't speak very well... But I'm starting to use QGIS, and I'm
>> trying to do some editions but I can't find some symple tools like:
>> - Create a new line with a specific length. (Sample: Create a line of
>> 5
>> meters)
> there is a plugin for this
The plugin has the bit misleading name "Improved polygon capturing" cause it also handles lines beside polygons.
It adds a button and a field for the specific lenght to the digitizing toolbar.
In editing mode of the layer, instead of the normal "add feature" button, click the button which has the tooltip "Capture Line with preset Edge Lenght" and set the desired length in the box. Click in the map to start drawing and move the mouse for setting the direction of the new line.
Right click to finish the line.
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374 _______________________________________________
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
