[Qgis-user] Text symbols
Andreas Neumann
a.neumann at carto.net
Fri Sep 28 02:12:14 PDT 2012
Currently there are only static solutions for road shields using marker lines. No way to dynamically fill in road nrs from db fields.
Over at the qgis-dev list we discussed your request. Larry Schaffer plans to work on it, extending the current label engine to have background shapes.
You have to be patient. Will take a couple weeks.
If you would be willing to pay for the development it would speed up things.
Andreas
"Peter Schürch" <p.schuerch at meierpartner.ch> schrieb:
>Hi Stephen
>You can place a buffer around the text, that enhances readability a
>lot. If you want to export your map to pdf or svg you should use
>new-style labelling (the Icon with the letters "ABC" on the toolbar),
>otherwise export fails. New-style labelling allows you to place labels
>parallel to lines, could be quite useful too.
>Other option (workaround) would be to have a shape layer with white
>rectangles beneath the text.
>Maybe someone has a better idea.
>Peter
>Von: qgis-user-bounces at lists.osgeo.org
>[mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Stephen
>Atkins
>Gesendet: Mittwoch, 26. September 2012 16:19
>An: qgis-user at lists.osgeo.org
>Betreff: [Qgis-user] Text symbols
>Hello everyone. I've been playing with QGIS for a couple of days now
>and really like it. My only problem is when labeling features.
>Specifically roads. I would like to have the highway number inside a
>shield (like signs on the road). I'm not sure how to do this and my
>searches on the web haven't been fruitful. Is this possible and if so
>can someone point me to it in the docs.
>Thanks.
>Stephen
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120928/7190acbc/attachment.html>
