[Qgis-user] QGis for bird surveys
Lynkos
lynkosmail at gmail.com
Thu Apr 4 11:10:43 PDT 2013
Mike that sounds like a great idea. Tomorrow I'll give it a try! Thanks,
Sarah.
2013/4/4 Michael Harte <mharte at ozemail.com.au>
> Sarah,
> To expand on what Rudi, Goyo, and Andreas have suggested with regard to
> converting data stored in spreadsheets and or text files to shapefiles I
> follow a work flow like:
> 1. Install "XY tools" using the Plug-in Manager (in menu - Plugins... Fetch Plug-ins... type xy in filter... XyTools 0.3.2... install);
> 2. After installation XY tools is found under the "Vector" menu item - make sure it is activated with a tick under "Plug-ins... Manage Plug-ins...";
> 3. Click "Vector... XY tools... Open Excel file as attribute table or point layer";
> 4. In dialogue box designate the columns in the spreadsheet that are the X and Y coordinates (Longitude or Easting = X; Latitude or Northing = Y) and click OK;
> 5. In the table of contents you will see a new layer called "Temporary Layer (volatile)" SAVE THIS LAYER (see below - if you don't it will disappear when you close your project);
> 6. Right click the temporary layer name and click "Save As..." (remember to set your coordinate system - CRS - easiest if it is the same as "Project CRS");
> This will save your data as an ESRI format shapefile
> 7. Tick the "Add saved file to map box in the Save As... dialogue; and
> 8. Apply desired symbology to the new layer.
> I hope I haven't insulted you with the step by step. Sometimes its nice
> just to have a cookbook for new tasks.
> The advantage of this workflow is that you can stick with using a
> spreadsheet to organise and store your data. The XY tools plug-in works
> with both MS Excel and Libre Office Calc spreadsheets. You never have to
> worry about converting your data to a text file. You can make separate
> files for each year's data or just keep concatenating new data onto your
> spreadsheet and creating an updated shapefile whenever you want to display
> the new data. All of your attributes should be carried over into the newly
> created shapefile. Make sure you have a header row with column headings in
> the first row of the spreadsheet and no blank rows in the body of the
> spreadsheet.
> Hope this helps.
> cheers,
> Mike
Con altri occhi - parole e immagini dalla parte della natura
www.lynkos.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130404/c0c4dddd/attachment.html>
