[Qgis-user] in Qgis master sextante help link lack "2.0/"
Agustin Diez-Castillo gvsig.mac at gmail.com
Mon Apr 15 04:46:50 PDT 2013
The following message in "Qgis master 48c6acb":
Oooops! SEXTANTE could not open the following output layers
   - Output raster layer:
   /var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/grassrmapcalculator3bbe9cd6db4941fcaa9cf9ba9cef01eb.tif
The above files could not be opened, which probably indicates that they
were not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were not
created as expected
This algorithm requires GRASS to be run. A test to check if GRASS is
correctly installed and configured in your system has been performed, with
the following result:
   *Error while checking GRASS installation. GRASS might not be correctly
   configured. Traceback (most recent call last): File
   "/Applications/QGIS_2.0-dev.app/Contents/Resources/python/plugins/sextante/grass/GrassUtils.py",
   line 335, in checkGrassIsInstalled from sextante.core.Sextante import
   runalg ImportError: cannot import name runalg*
Click here<http://docs.qgis.org/html/en/docs/user_manual/sextante/3rdParty.html>
 to know more about how to install and configure GRASS to be used with
SEXTANTE
points to
instead of
http://docs.qgis.org/2.0/html/en/docs/user_manual/sextante/3rdParty.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130415/0d6c13da/attachment.html>
