[Qgis-user] in Qgis master sextante help link lack "2.0/"
Victor Olaya volayaf at gmail.com
Mon Apr 15 05:31:02 PDT 2013
The QGIS website is being renovated, and that's why the link is not
working. Anyone can confirm a link that is stable and will not be
changes, to point to it from the error window?
Thanks!
2013/4/15 Agustin Diez-Castillo <gvsig.mac at gmail.com>:
> The following message in "Qgis master 48c6acb":
> Oooops! SEXTANTE could not open the following output layers
> Output raster
> layer:/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/grassrmapcalculator3bbe9cd6db4941fcaa9cf9ba9cef01eb.tif
> The above files could not be opened, which probably indicates that they were
> not correctly produced by the executed algorithm
> Checking the log information might help you see why those layers were not
> created as expected
> This algorithm requires GRASS to be run. A test to check if GRASS is
> correctly installed and configured in your system has been performed, with
> the following result:
> Error while checking GRASS installation. GRASS might not be correctly
> configured. Traceback (most recent call last): File
> "/Applications/QGIS_2.0-dev.app/Contents/Resources/python/plugins/sextante/grass/GrassUtils.py",
> line 335, in checkGrassIsInstalled from sextante.core.Sextante import runalg
> ImportError: cannot import name runalg
> Click here to know more about how to install and configure GRASS to be used
> with SEXTANTE
> points to
> http://docs.qgis.org/html/en/docs/user_manual/sextante/3rdParty.html
> instead of
> http://docs.qgis.org/2.0/html/en/docs/user_manual/sextante/3rdParty.html
> Qgis-user mailing list
