[Qgis-user] lost 'fetch python plugins' and vector menu
Robert Nuske rnuske at gwdg.de
Fri Jul 5 03:33:01 PDT 2013
Hi Albin,
thanks a lot for pointing me in the right direction!
The solution for me was to have just the repository qgis.org/debian in my
sources.list and not ubuntugis-unstable.
It started with both repositories and than removed qgis.org/debian, because
I had very positive experiences with ubuntugis-unstable in the past. That was
obviously wrong.
cheers
  robert
Am Freitag, 5. Juli 2013, 08:46:01 schrieb Albin Blaschka:
> Am 04.07.2013 18:45, schrieb Robert Nuske:
> >> tried this link,
> >> http://qgismalaysia.blogspot.com/2013/04/ubuntu-1304-and-qgis.html
> > It describes how to install qgis-master, if I understood it correctly.
> > But I am looking for the last stable release (QGIS 1.8).
> Hello!
> on 2 July I reported a similar experience in the already other mentioned
> thread ("Fetch plugins missing"):
> > At first I added the ubuntu-gis-repository (ppa), but that gave me
> > a old version of QGIS, so I added the repository given at the
>  > download-page (http://qgis.org/debian raring main) and did an update,
>  > with which I got QGIS 1.8 as wished, but with missing "fetch plugins".
>  > I had to remove the ubuntugis ppa and doing a
> > "sudo aptitude update && sudo aptitude safe-upgrade" brought it back...
> HTH!
> Albin
> >> 2013/7/4 Robert Nuske <rnuske at gwdg.de>
> >>> Hi Etienne,
> >>> yes you are right, I obviously looked not carefully enough...
> >>> Anyhow, the given solution is not working for me.
> >>> python-pyspatialite is not installed, at least not after purging
> >>> all qgis packages.
> >>> I now also removed libspatialite5 and libspatialite3, which tore down
> >>> the
> >>> entire grass and gdal
> >>> Then started again with installing qgis (ends up pulling again
> >>> libspatialite3
> >>> and libspatialite5 ), but nothing changed.  Still no  'fetch python
> >>> plugins'
> >>> and no vector menu
> >>> Is there another repository I should use besides or instead
> >>> ubuntugis-unstable?
> >>> cheers,
> >>>    robert
> >>> Am Donnerstag, 4. Juli 2013, 12:07:02 schrieb Etienne Tourigny:
> >>>> another user reported in a separate thread of this same list a few days
> >>> ago
> >>>> (subject is "Fetch plugins missing")
> >>>> "I had to remove python-pyspatialite to get a correct installation of
> >>>> python-qgis and get the python plugins working"
> >>>> It's always a good idea to look for existing solutions in the mailing
> >>> list
> >>>> before posting...
> >>>> cheers
> >>>> Etienne
> >>>> On Thu, Jul 4, 2013 at 12:02 PM, Robert Nuske <rnuske at gwdg.de> wrote:
> >>>>> Dear partners in misery and merciful helpers,
> >>>>> I've got the feeling the 1.8.0-2~raring1 QGIS package from
> >>>>> ubuntugis-unstable for 13.04 64bit is broken.
> >>>>> Yes, I did
> >>>>> - purge every qgis package separately
> >>>>> - delete all the .qgis folders
> >>>>> - now also reboot and aptitude update & aptitude dist-upgrade
> >>>>> (no idea what for)
> >>>>> - a fresh install of the qgis package
> >>>>> The old 1.8.0-1~quantal3 32bit QGIS package on another computer works
> >>>>> like a charm. I hope I do not have to build from source to get a
> >>> working
> >>>>> QGIS 1.8 on a recent Ubuntu.
> >>>>> Is the package really broken or did I do something utterly wrong?
> >>>>> cheers,
> >>>>> robert
> >>>>> Am Donnerstag, 4. Juli 2013, 14:53:44 schrieb Saber Razmjooei:
> >>>>>> If you run qgis from terminal, what error message(s) do you get?
> >>>>>> From: Joshua Hattingh [mailto:josh at rockstock.co.za]
> >>>>>> Sent: 04 July 2013 14:52
> >>>>>> To: Saber Razmjooei
> >>>>>> Cc: Nathan Woodrow; qgis-user at lists.osgeo.org; Robert Nuske
> >>>>>> Subject: Re: [Qgis-user] lost 'fetch python plugins' and vector menu
> >>>>>> Tried that, still no luck - no fetch python plugins and no
> >>>>>> openlayers
> >>>>>> plugin.
> >>>>>> J
> >>>>>> On 4 July 2013 15:42, Saber Razmjooei
> >>>>>> <saber.razmjooei at lutraconsulting.co.uk> wrote:
> >>>>>> If you are using 1.8, I guess there is no API change for it, so the
> >>>>>> following should do:
> >>>>>> sudo apt-get purge python-qgis
> >>>>>> sudo apt-get update
> >>>>>> sudo apt-get dist-upgrade
> >>>>>> sudo apt-get install python-qgis
> >>>>>> Just to be 100% sure!
> >>>>>> Cheers
> >>>>>> Saber
> >>>>>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
> >>>>>> From: qgis-user-bounces at lists.osgeo.org
> >>>>>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Joshua
> >>> Hattingh
> >>>>>> Sent: 04 July 2013 14:38
> >>>>>> To: Nathan Woodrow
> >>>>>> Cc: qgis-user at lists.osgeo.org; Robert Nuske
> >>>>>> Can we fix our installations? If so, how? In point form. Do A then B
> >>>>> then C
> >>>>>> etc.
> >>>>>> Thanks,
> >>>>>> J
> >>>>>> On 4 July 2013 15:34, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> >>>>>> The plugin install has been merged into the plugin manager.
> >>>>>> The API has also chmaged so all plugins need to be updated. This is
> >>> why
> >>>>> you
> >>>>>> are missing some of the plugins you used to have.
> >>>>>> Sent from some fancy phone looking thingo
> >>>>>> _____
> >>>>>> Sent: 4/07/2013 11:29 PM
> >>>>>> To: Robert Nuske
> >>>>>> Hi Robert
> >>>>>> I have the same problem (I'm trying to get Openlayers plugin but
> >>>>>> also
> >>>>> don't
> >>>>>> have the "Fetch Python Plugins" menu option, and can't get help
> >>>>>> anywhere,
> >>>>>> been through the same methods as you. I'm on Raring and 1.8 or 1.9
> >>> and
> >>>>> same
> >>>>>> problem on both. I've tried for 2 weeks to fix but cannot. Let me
> >>> know
> >>>>>> if
> >>>>>> you find the secret. There's a fix but it doesn't work for me.
> >>>>>> Regards,
> >>>>>> Josh
> >>>>>> On 4 July 2013 14:38, Robert Nuske <rnuske at gwdg.de> wrote:
> >>>>>> Dear QGISers,
> >>>>>> somehow I have no vector menu and can not find the menu entry
> >>>>>> 'fetch python plugins'.
> >>>>>> Being on Kubuntu 13.04 64bit I have my QGIS (1.8.0-2~raring1) from
> >>>>>> ubuntugis-unstable.
> >>>>>> I deleted any .qgis folders, purged any qgis package and did a fresh
> >>>>> install
> >>>>>> of qgis (aptitude install qgis). I have no clue what else I
> >>> could/should
> >>>>>> try.
> >>>>>> Any help is more than appreciated
> >>>>>> cheers,
> >>>>>> robert
> >>>>>> Additional Information:
> >>>>>> $ sudo apt-cache policy qgis
> >>>>>> qgis:
> >>>>>> Installiert: 1.8.0-2~raring1
> >>>>>> Installationskandidat: 1.8.0-2~raring1
> >>>>>> Versionstabelle:
> >>>>>> *** 1.8.0-2~raring1 0
> >>>>>> 500 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/
> >>>>>> raring/main amd64 Packages
> >>>>>> 100 /var/lib/dpkg/status
> >>>>>> 1.7.4+1.7.5~20120320-1.1 0
> >>>>>> 500 http://de.archive.ubuntu.com/ubuntu/ raring/universe amd64
> >>> Packages
> >>>>>> $ sudo aptitude search qgis
> >>>>>> p libqgis-dev - Quantum GIS - development files
> >>>>>> p libqgis-dev:i386 - Quantum GIS - development files
> >>>>>> p libqgis1.7.5 - Quantum GIS - shared libraries
> >>>>>> p libqgis1.7.5:i386 - Quantum GIS - shared libraries
> >>>>>> i A libqgis1.8.0 - Quantum GIS - shared libraries
> >>>>>> p libqgis1.8.0:i386 - Quantum GIS - shared libraries
> >>>>>> i A python-qgis - Python bindings to Quantum GIS
> >>>>>> p python-qgis:i386 - Python bindings to Quantum GIS
> >>>>>> i A python-qgis-common - Python bindings to Quantum GIS - ar
> >>>>>> v python2.7-qgis -
> >>>>>> v python2.7-qgis:i386 -
> >>>>>> i qgis - Geografisches Informationssystem (G
> >>>>>> p qgis:i386 - Geografisches Informationssystem (G
> >>>>>> p qgis-api-doc - Quantum GIS API documentation
> >>>>>> i A qgis-common - Quantum GIS - architecture-independ
> >>>>>> v qgis-dev -
> >>>>>> v qgis-dev:i386 -
> >>>>>> p qgis-mapserver - Quantum GIS mapserver
> >>>>>> p qgis-mapserver:i386 - Quantum GIS mapserver
> >>>>>> i A qgis-plugin-globe - OSG globe plugin for Quantum GIS
> >>>>>> p qgis-plugin-globe:i386 - OSG globe plugin for Quantum GIS
> >>>>>> i A qgis-plugin-globe-common - OSG GLOBE plugin for Quantum GIS -
> >>>>>> i A qgis-plugin-grass - GRASS plugin for Quantum GIS
> >>>>>> p qgis-plugin-grass:i386 - GRASS plugin for Quantum GIS
> >>>>>> i A qgis-plugin-grass-common - GRASS plugin for Quantum GIS - arch
> >>>>>> i A qgis-providers - collection of data providers to Qua
> >>>>>> p qgis-providers:i386 - collection of data providers to Qua
> >>>>>> i A qgis-providers-common - collection of data providers to Qua
> >>>>>> p qgis-sqlanywhere - Quantum GIS sql anywhere plugin and
> >>>>>> p qgis-sqlanywhere:i386 - Quantum GIS sql anywhere plugin and
> >>>>>> p qgis-sqlanywhere1.7.5 - Quantum GIS sql anywhere plugin and
> >>>>>> p qgis-sqlanywhere1.7.5:i386 - Quantum GIS sql anywhere plugin and
> >>>>>> _______________________________________________
> >>>>>> Qgis-user mailing list
> >>>>>> Qgis-user at lists.osgeo.org
> >>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>>>> _____
> >>>>>> This email and any files transmitted with it are confidential and
> >>>>> intended
> >>>>>> solely for the use of the individual or entity to whom they are
> >>>>> addressed.
> >>>>>> If you have received this email in error please notify the system
> >>>>> manager.
> >>>>>> This message contains confidential information and is intended only
> >>> for
> >>>>> the
> >>>>>> individual named. If you are not the named addressee you should not
> >>>>>> disseminate, distribute or copy this e-mail. Please notify the
> >>>>>> sender
> >>>>>> immediately by e-mail if you have received this e-mail by mistake
> >>>>>> and
> >>>>> delete
> >>>>>> this e-mail from your system. If you are not the intended recipient
> >>> you
> >>>>> are
> >>>>>> notified that disclosing, copying, distributing or taking any action
> >>> in
> >>>>>> reliance on the contents of this information is strictly prohibited.
> >>>>>> Whilst reasonable care has been taken to avoid virus transmission,
> >>>>>> no
> >>>>>> responsibility for viruses is taken and it is your responsibility to
> >>>>> carry
> >>>>>> out such checks as you feel appropriate.
> >>>>>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
