[Qgis-user] [Ubuntu] MrSID for QGIS 1.8 in Ubuntu Precise
Agustin Lobo alobolistas at gmail.com
Mon May 20 12:15:15 PDT 2013
Justin,
I also have a copy of Geo_DSDK-7.0.0.2167 but I get the following error after
sudo gdal-mrsid-build $HOME/Geo_DSDK-7.0.0.2167
configure: error: libgeotiff is required to build GDAL MrSID driver
while libgeotiff is actually installed.
This error has been reported a long time ago:
http://trac.osgeo.org/ubuntugis/ticket/21
How where you able to go around this problem?
Thanks,
Agus
On Mon, Sep 17, 2012 at 5:34 PM, Justin Penka <jpenka at sdrmaps.com> wrote:
> That tutorial is woefully outdated... I tried to compile Mr.Sid support
> using the 8.0 version of the lizardtech dsdk sometime ago but never could
> get it working, original post is below:
> http://lists.osgeo.org/pipermail/ubuntu/2011-September/000422.html
> I ended up just reverting to using the older mrsid 7.0 dsdk, it was not easy
> to find but I kept a copy of it around if you need it.
> -Justin
> -----Original Message-----
> From: ubuntu-bounces at lists.osgeo.org on behalf of Hamish
> Sent: Fri 9/14/2012 5:04 PM
> To: giovanni.manghi at faunalia.pt
> Cc: qgis-user at lists.osgeo.org; ubuntu at lists.osgeo.org; pedrof at utad.pt
> Subject: Re: [Ubuntu] [Qgis-user] MrSID for QGIS 1.8 in Ubuntu Precise
> Giovanni wrote:
>> I believe he is referring to the lack of the libgdal-mrsid package,
>> available for older Ubuntu releases in the ubuntugis repository.
> (documented here:  http://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid)
> regards,
> Hamish
> UbuntuGIS mailing list
> Ubuntu at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/ubuntu
