[Qgis-user] A doubt on SPIT- Shapefile to PostGIS Import Tool-reg.
Etienne Tourigny
etourigny.dev at gmail.com
Tue May 21 14:03:17 PDT 2013
On Tue, May 21, 2013 at 5:47 AM, Jaisen Nedumpala <jaisuvyas at gmail.com>wrote:
> Ok. Let me be more specific. My problems with latest QGIS and GRASS went
> like this:
> I have added the QGIS repository to my apt sources and installed latest
> QGIS build, following this link:
> http://hub.qgis.org/projects/quantum-gis/wiki/Download#21-Debian
> I have also downloaded the latest GRASS binaries from this link:
> http://download.osgeo.org/grass/grass64/binary/linux/debian/squeeze/i386/
> and installed.
did you see the line on the qgis download page that says
Note: Please remove all the QGIS and GRASS packages you may have installed
from other repositories before doing the update.
This probably means that you should also not install grass through other
means after installing qgis...
I don't use debian but my guess is that installing qgis and
qgis-plugin-grass probably installs a compatible grass (6.4.2 from the
looks of it)... I guess if you need a more recent grass you need to build
qgis yourself...
cheers
Etienne
At least this happens when using ubuntu and derivatives
> After that, Individually both of them worked fine. But I couldn't access
> GRASS tool box from within QGIS interface. So couldn't perform the analyses
> available in GRASS within QGIS. So I reverted back to the earlier versions
> of both within which, I could perform all these analyses very well. It is
> my wish, there would be available a single Debian repository with latest
> QGIS and GRASS available, both compiled as one can access GRASS tool box
> from QGIS. But such a thing isn't exist now. I don't remember the exact
> error messages I got when I accessed GRASS tool box from the latest QGIS
> interface.
> Now tell me how did you achieved both working fine? Did you compiled both
> from sources? Kindly tell me in detail.
> 2013/5/20 Paolo Cavallini <cavallini at faunalia.it>
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Il 20/05/2013 11:02, Jaisen Nedumpala ha scritto:
>> > It is not the problem, that I don't know the download page. I have
>> > tried the latest builds of QGIS and GRASS already. But the sad
>> > thing is that they are not working fine together. That is why I
>> > stick on to this
>> Please be more specific: it should work, and it does in all my Debian
>> boxes.
>> All the best.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAlGaGDsACgkQ/NedwLUzIr4lIACgmkUmo3mvpdCz+D4FC5SV1Q/k
>> kkQAoIKqz+LIFv6htEUFBCHqUizkwTdX
>> =zZKA
>> -----END PGP SIGNATURE-----
> - നെടുമ്പാല ജയ്സെന് -
> «´¨`·* . Jaisen . *..´¨`»
> ( `v´ )
> `v´
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/fa2ba0f1/attachment.html>
