[Qgis-user] Displaying the command of Database Shapefile Loader
Etienne Tourigny etourigny.dev at gmail.com
Fri Apr 18 16:09:49 PDT 2014
If you are referring to the DB Manager plugin, it uses the QGIS API to
import shapefiles, not the external tool shp2pgsql.
Etienne
On Fri, Apr 18, 2014 at 11:26 AM, Gunnar Oehmichen
<oehm8895 at uni-landau.de>wrote:
> Hello There,
> Using QGIS 2.2 on Ubuntu 12.04.
> I uploaded a shapefile to a remote postgis-database using the
> DatabaseManger -> Import Shapefile.
> Is it possible to display the shp2pgsql command qgis used to load a
> shapefile to a postgisdatabase (I guess QGIS is just using the tool). I
> would like to compare this command to what Ive entered manually into the
> terminal, producing the following error (Probably not belonging here):
> I tried to do a shp2pgsql command:
> shp2pgsql -i shapefile.shp schema.test | psql -h localhost -d 'DB' -U
> oehmichen
> Shapefile type: Polygon
> Postgis type: MULTIPOLYGON[2]
> Password for user USER:
> SET
> SET
> BEGIN
> NOTICE:  CREATE TABLE will create implicit sequence "test_gid_seq" for
> serial column "test.gid"
> CREATE TABLE
> NOTICE:  ALTER TABLE / ADD PRIMARY KEY will create implicit index
> "test_pkey" for table "test"
> ALTER TABLE
>                  addgeometrycolumn
>  planee.test.geom SRID:0 TYPE:MULTIPOLYGON DIMS:2
> (1 row)
> ERROR:  invalid input syntax for type numeric: "7313000,000000000000000"
> LINE 1: ...56Z','Basis-DLM','urn:adv:oid:9110','301IRDC_006','7313000,0...
> Thanks for your help,
> Gunnar
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140418/0e6235a8/attachment.html>
