[Qgis-user] Atlas: Is there a way to synchronize canvas to atlas preview?
kimaidou kimaidou at gmail.com
Mon Apr 21 00:28:18 PDT 2014
Hi all
Considering the atlas scale settings, what about being able to use an
expression to define the scale to use feature by feature ? This way we
could use a set of scales instead of choosing only one, and so we can know
in advance how to set the layers properties like labels and style to render
as desired for each scale.
Michael
2014-04-21 2:33 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 14/03/2014 12:28 am, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
> wrote:
> > Hi,
> > I wonder if there is a way to synchronize the maps canvas with the Atlas
> preview (like with the georeferencer where the bitmap gets synced with the
> map canvas or vice versa)
> > This would be quite handy for adjusting the labelling in case I need to.
> Labelling and the adjusting of it for the final layout is by far the most
> time-consuming aspect of my hole project. I use the "Layer to labelled
> layer"-plugin to store my corrections.
> > My workflow right now is to prepare the Atlas coverage and click through
> the individual preview items (10% margin), then activate the coverage
> attribute table, search for the coverage item, select it, zoom to it,
> deactivate the selection, then read the scale for the atlas item and write
> it into to canvas scale to have the same representation on the canvas as in
> the atlas preview.
> > Now I can adjust my labels (drag them to better positions) in the canvas
> and can be sure that they will look the same in the Atlas export.
> Hi Bernd,
> This is a really good idea. I've just added a button to the map item
> properties in the composer: "View extent in map canvas". This sets the main
> map canvas to match the extent of the current map item. Does this sound
> like the kind of thing you are after?
> Nyall
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140421/24ceb3f7/attachment.html>
