[Qgis-user] Atlas: Is there a way to synchronize canvas to atlas preview?
Alexandre Neto
senhor.neto at gmail.com
Mon Apr 21 01:43:46 PDT 2014
Hello,
Indeed a very nice and handy idea. I have already experienced the trouble
of moving a label in map canvas without knowing exactly how it will look in
the composer. Bernd's methodology helps.
Tho a fit map canvas to atlas preview extents is quite nice, IMHO, a "scale
and pan" map canvas to atlas item would be even nicer.
A part from the atlas, another more advanced (as probably more difficult to
achieve) would be the ability to temporarily lock map canvas representation
to a scale (normally the printing scale). This would mean, that if you zoom
in or out, the width of the symbols and the labels would increase and
decrease accordingly. This would be quite helpful when you want to give
some final touches in a map, And you want to make sure some element\labels
don't touch each other.
Thanks for your great work,
Alexandre Neto
On Mon, Apr 21, 2014 at 1:33 AM, Nyall Dawson <nyall.dawson at gmail.com>wrote:
> On 14/03/2014 12:28 am, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
> wrote:
> > Hi,
> > I wonder if there is a way to synchronize the maps canvas with the Atlas
> preview (like with the georeferencer where the bitmap gets synced with the
> map canvas or vice versa)
> > This would be quite handy for adjusting the labelling in case I need to.
> Labelling and the adjusting of it for the final layout is by far the most
> time-consuming aspect of my hole project. I use the "Layer to labelled
> layer"-plugin to store my corrections.
> > My workflow right now is to prepare the Atlas coverage and click through
> the individual preview items (10% margin), then activate the coverage
> attribute table, search for the coverage item, select it, zoom to it,
> deactivate the selection, then read the scale for the atlas item and write
> it into to canvas scale to have the same representation on the canvas as in
> the atlas preview.
> > Now I can adjust my labels (drag them to better positions) in the canvas
> and can be sure that they will look the same in the Atlas export.
> Hi Bernd,
> This is a really good idea. I've just added a button to the map item
> properties in the composer: "View extent in map canvas". This sets the main
> map canvas to match the extent of the current map item. Does this sound
> like the kind of thing you are after?
> Nyall
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140421/43e6680c/attachment.html>
