[Qgis-user] Atlas: Is there a way to synchronize canvas to atlas preview?
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Mon Apr 21 23:46:44 PDT 2014
Am 21.04.2014, 02:33 Uhr, schrieb Nyall Dawson <nyall.dawson at gmail.com>:
> On 14/03/2014 12:28 am, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
> wrote:
>> Hi,
>> I wonder if there is a way to synchronize the maps canvas with the
>> Atlas preview (like with the georeferencer where the bitmap gets synced
>> with >the map canvas or vice versa)
>> This would be quite handy for adjusting the labelling in case I need
>> to. Labelling and the adjusting of it for the final layout is by far
>> the most >time-consuming aspect of my hole project. I use the "Layer to
>> labelled layer"-plugin to store my corrections.
>> My workflow right now is to prepare the Atlas coverage and click
>> through the individual preview items (10% margin), then activate the
>> coverage >attribute table, search for the coverage item, select it,
>> zoom to it, deactivate the selection, then read the scale for the atlas
>> item and write it >into to canvas scale to have the same representation
>> on the canvas as in the atlas preview.
>> Now I can adjust my labels (drag them to better positions) in the
>> canvas and can be sure that they will look the same in the Atlas export.
Hi Nyall,
great that you dug out that old request!
> Hi Bernd,
> This is a really good idea. I've just added a button to the map item
> properties in the composer: "View extent in map canvas". This sets the
> main map >canvas to match the extent of the current map item. Does this
> sound like the kind of thing you are after?
In case that this button does all what I described as my workflow
beforehand: Yes, thats what I'm after.
Alternatively, could there be maybe a checkbox at the Atlas generation tab
or in the "Controlled by atlas"-part which sets this behavior permanently?
This would even reduce the work to just switching the Atlas preview item.
Or as I said before, a switch like in georeferencer to sync the canvas to
the composer extend ...
Anyway, great improvement so far.
Cheers
Bernd
> Nyall
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/0e162bad/attachment.html>
