[Qgis-user] Data Defined symbol attributes: default fields
Andreas Neumann
a.neumann at carto.net
Tue Apr 29 13:28:39 PDT 2014
Hi Carlos,
You will have to assign for every layer and every graphical property you
want to set. The valid values are displayed on mouse-over if you move
your mouse above the yellow buttons for the labels, and in the "help"
column in the table where you assign the values for other symbology
options. Either it lists the data type (e.g. double) or valid string values.
Andreas
Am 29.04.2014 18:18, schrieb Carlos da Ponte:
> Hi all,
> With respect to the data defined symbol attributes, if I create fields with
> specific names in my database tables will QGIS automatically use these
> fields for the data defined symbol attributes (if so what are these field
> names) or do I need assign these fields in the symbology preferences for
> every layer? Is there a list of the valid data defined values?
> Thanks!
> C
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Data-Defined-symbol-attributes-default-fields-tp5137834.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
