[Qgis-user] Data Defined symbol attributes: default fields
Alex Mandel tech_dev at wildintellect.com
Tue Apr 29 13:41:21 PDT 2014
Sounds like a good plugin idea similar to
http://plugins.qgis.org/plugins/toLabeledLayer/
or
http://plugins.qgis.org/plugins/EasyCustomLabeling/
Thanks,
Alex
On 04/29/2014 01:28 PM, Andreas Neumann wrote:
> Hi Carlos,
> You will have to assign for every layer and every graphical property you
> want to set. The valid values are displayed on mouse-over if you move
> your mouse above the yellow buttons for the labels, and in the "help"
> column in the table where you assign the values for other symbology
> options. Either it lists the data type (e.g. double) or valid string values.
> Andreas
> Am 29.04.2014 18:18, schrieb Carlos da Ponte:
>> Hi all,
>> With respect to the data defined symbol attributes, if I create fields with
>> specific names in my database tables will QGIS automatically use these
>> fields for the data defined symbol attributes (if so what are these field
>> names) or do I need assign these fields in the symbology preferences for
>> every layer?  Is there a list of the valid data defined values?
>> Thanks!
>> C
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/Data-Defined-symbol-attributes-default-fields-tp5137834.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
