[Qgis-user] reload WMS raster
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Dec 13 21:58:04 PST 2014
Specify a tile size like 300x300 in the wms setting.  In your network option(Setting\options\network), you are able to increase the size of the cashe.  I know the first option works, the second option not sure but I do it anyway...
Use "cache to speed up" in the rendering options.(setting\option\rendering).
Also, I usually have 2 wms layers at once.  One with more layers (Slow), and one with only one layer like the road or water (fast).  I keep only the second one on. When I am where I want to be, I turn on the first, more complex layer.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2014-12-13 19:34, "Jake Maier [via OSGeo.org]" <ml-node+s1560n5177790h51 at n6.nabble.com> a écrit :
> I mostly work with WMS raster files. Each time I change anything, turning on or off layers, editing layers etc, the WMS reloads the raster even if there is no change in the underlying data of the raster. I have a slow connection and it drives me crazy to wait each time I move vertices. I often use ‘save as image’ and load the image, but I already have too many of those temporary rasters and still I find myself using sections or magnification where the rasters I copied are insufficient. Is there a trick to speed up the process of editing the canvas without the WMS reloading?
> Thanks for any help
> Jake
> Qgis-user mailing list
> [hidden email]
> ________________________________
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/reload-WMS-raster-tp5177790.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/reload-WMS-raster-tp5177790p5177795.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141213/1823adc5/attachment.html>
