[Qgis-user] Can't add multiple features to a layer
Richard McDonnell richard.mcdonnell at opw.ie
Wed Feb 12 01:12:39 PST 2014
Sounds like a snapping issue, if you check the attribute table, are all
the points there? Switch snap off  for the layer you are working on, or
change the tolerance to a lower setting.
Hope this helps,
Richard.
On 12/02/2014 05:46, Richard Tardif wrote:
> I am unable to add more than one feature to a layer. I can
> successfully add one feature, whether polygon or point, saving its
> attributes etc. But when I try to add another polygon by clicking
> anywhere on the map I don't get the red line that indicates the start
> of the next polygon build. Depending where I click various nodes of
> the original polygon sometimes change colour. Likewise if I'm adding
> points clicking will bring up the attribute dialog box but when that
> is completed no new dot appears on the map, just the dot of the first
> feature.
> I am running QGIS 2.0.2-Dufour on Mavericks (10.9.1) on MacBook Air.
> Qgis-user mailing list
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140212/c6479e88/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140212/c6479e88/attachment.vcf>
