[Qgis-user] Spatialite VIEW in QGIS question
Olivier Dalang
olivier.dalang at gmail.com
Wed Feb 19 11:02:22 PST 2014
Dear Bernd,
I encountered some similar problems with Spatialite views, but in the end I
had it working (sometimes) both in 2.0 and in master... I used the manual
method from the spatialite cookbook though (not the Spatialite GUI).
I have no time to test now, but from what I recall, this does not work :
CREATE VIEW AS SELECT name, geometry FROM table
while this works :
CREATE VIEW AS SELECT ROWID, name, geometry FROM table
Maybe you want to give it a last try. I can testify I have some working
spatialite views here. Let us know if this works, if not I may give it a
better look when I have some time.
Another method is running a SELECT query in the DB Manager in QGIS, and
then choosing "Add to map canvas". This is not an actual sqlite view, but
depending on what you need, it could be enough.
Good luck !
Olivier
2014-02-19 19:54 GMT+01:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
> Am 19.02.2014 19:14, schrieb Steve G:
> This does not directly answer your question about spatialite views, but
>> you
>> might be able to use relationships directly in QGIS in the near future (I
>> think this is a 2.1 update). See:
>> http://blog.vitu.ch/10112013-1201/qgis-relations
>> -Steve
> Hi Steve,
> Actually I do not care by which means I reach my destination, but I had
> the, maybe wrong; impression that using a spatial database would do the
> trick.
> Anyway ...
> I already installed latest master cause I read about this relation manager
> thing a while ago ... but I was left quite clueless about how to use it.
> Searched the web for nearly an hour about any info but to no avail, so
> many thanks for sharing the link!!
> Will have a look at it ASAP, maybe thats kind of a solution.
> Cheers
> Bernd
>> View this message in context: http://osgeo-org.1560.x6.
>> nabble.com/Spatialite-VIEW-in-QGIS-question-tp5104565p5104775.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140219/64fdb342/attachment.html>
