[Qgis-user] QGIS with digitizing board/tablet
Benoit de Cabissole
benoit-3 at bc-consult.com
Fri Feb 21 00:21:58 PST 2014
Hi Tom,
Perhaps the following reference could be of help to you when you start
writing the plugin:
Computers&Geosciences: 1986, V12, pp175-197 - DIGMAP: a computer program
for accurate acquisition by digitizer of geographical coordinates from
conformal projections. (FORTRAN IV code on a Z-80!!!)
Regards,
Benoit
On 21/02/2014 09:56, Thomas Colley wrote:
> Hi Nathan
> Thanks for replying. From what I can understand it's just a case of georeferencing the drawing on the board in the same way as you would a raster on the screen.
> ArcMap takes a text file with at least 4 coordinate pairs from the drawing on the board that it uses to tie the digitizing area into the on screen CRS.
> So I hope it might be relatively easy to implement a plugin that can accept these coordinates then apply some sort of shift to any input from the drawing board.
> I'll try and get some more info on how it works in ArcMap.
> Thanks again
> Tom
> FROM: Nathan Woodrow [mailto:madmanwoo at gmail.com]
> SENT: 20 February 2014 12:54
> TO: Thomas Colley
> CC: qgis-user
> SUBJECT: Re: [Qgis-user] QGIS with digitizing board/tablet
> Hey Thomas,
> Wouldn't it just pick it up like a mouse? Qt does have support for more pressure based devices but QGIS doesn't take advantage of it. It will work fine if it acts like a mouse though.
> - Nathan
> On Thu, Feb 20, 2014 at 10:50 PM, Thomas Colley <t.colley at neath-porttalbot.gov.uk> wrote:
> Hi
> Is it possible to use QGIS with a digitizing board/tablet?
> I've had a search but can't find any information on this.
> The board I am trying to use is a CalComp DrawingBoard III that our users have been using with ArcMap.
> If it's not currently possible in QGIS I will look at creating a plugin for it.
> Thanks
> Tom
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140221/f0ece70c/attachment.html>
