[Qgis-user] QGIS 2.2 - Remove layer dialog
Alexandre Neto senhor.neto at gmail.com
Wed Feb 26 04:21:01 PST 2014
Hello all,
On Wed, Feb 26, 2014 at 11:22 AM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Also, no-one has commented on the fact that delete and Backspace don't
> seem to work for me in 2.2. Do they work for others?
I believe that this was also agreed in the previous discussion. "delete"
and "backspace" keys are now for feature delete only and Ctrl+D (can be
changed in shortcut options) is for removing layer.
On 02/25/2014 10:56 AM, Andreas Neumann wrote:
Hi, We decided that for actions without an undo there needs to be a
> confirmation. That's a common behaviour of most software.
+ 1 For this behavior. It's always good to prevent the loss of work when a
undo is not available.
Richard said:
> Settings dialogs are getting more and more crowded with options I do
> really not know anymore for which minimal detail it is giving me options
> for.
I also thinks that filling the options menus with costumizable behaviors to
adress everybody wishes can be overwhelming for most users.
IMHO, the cleanest solution would be to be able to Undo the remove layer.
And I would create a brand new feature request for that, instead of opening
and closing the bug report until we all agree.
Anyway, It will not always be possible to make everybody happy, and this
double extended discussion shows the importance of users and developers get
themselves involved in the User Experience discussions (
qgis-ux at lists.osgeo.org), so we can make a plan and then keep with it, and
make QGIS behaviour a more consistent.
cheers,
Alexandre Neto
> Just my thupence. :-)
> Cheers,
> Jonathan
>> On Tue, Feb 25, 2014 at 5:57 PM, Richard Duivenvoorde <
>> rdmailings at duif.net> wrote:
>>> Hi Etienne,
>>> I'm fine with the solution of Jef: make it an option (now that it is
>>> done).
>>> But in general: I do not like the fact that we had, I think, a
>>> discussion of about 2 weeks with several people, which is thrown out of
>>> the window because one reopens an issue and makes some noise. Apparently
>>> the time we/I put into this discussion was not worth my time.
>>> Besides this: I do not think having an option for everything is the best
>>> option ;-)
>>> Better to have a sensible default, have a discussion/voting and then
>>> deal with that. An extra setting I see as a bad compromise here. The
>>> for.
>>> Please let us create some (ui/hud) vision and hold on to that, so we are
>>> not driving on user comments only.
>>> Regards,
>>> On 25-02-14 18:24, Etienne Tourigny wrote:
>>> > I find it rather annoying also, and re-opened the bug.
>>> > On Tue, Feb 25, 2014 at 2:11 PM, Jonathan Moules
>>> > <jonathanmoules at warwickshire.gov.uk
>>> > <mailto:jonathanmoules at warwickshire.gov.uk>> wrote:
>>> >     Hi Jürgen,
>>> >     Thanks for the link.
>>> >     From attempting to read that:
>>> >     - There's no way to turn it off. :-(
>>> >     - Shortcuts must be used instead. :-(
>>> >     - Delete or Backspace should delete a layer without asking for
>>> >     confirmation.
>>> >     Is this correct?
>>> >     Because if so, neither Delete nor Backspace works - they don't do
>>> >     anything at all. Am I doing something wrong?
>>> >     (Ctrl-D works - but that brings up the dialog... :-S )
>>> >     Did I miss something or is this a bug?
>>> >     Best,
>>> >     Jonathan
>>> >     On 25 February 2014 16:34, Jürgen E. <jef at norbit.de
>>> >     <mailto:jef at norbit.de>> wrote:
>>> >         Hi Jonathan,
>>> >         On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
>>> >         >   QGIS 2.2 has a confirmation dialog when I go to remove a
>>> >         layer; Maybe
>>> >         > it's me but I'm sure the previous versions didn't -
>>> >         alternately I can't
>>> >         > find a setting anywhere to turn this behaviour off (I'm
>>> >         assuming I did in
>>> >         > the past if it was there).
>>> >         > Is this a new feature or have I just lost the setting?
>>> >         Personally I find it
>>> >         > quite annoying so would like to disable it.
>>> >         See #9094[1]
>>> >         Jürgen
>>> >         [1] http://hub.qgis.org/issues/9094
>>> >         Jürgen E. Fischer         norBIT GmbH               Tel.
>>> >         +49-4931-918175-31
>>> >         Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>>> >         +49-4931-918175-50
>>> >         Software Engineer         D-26506 Norden
>>> >         http://www.norbit.de
>>> >         QGIS PSC member (RM)      Germany                      IRC: jef
>>> >         on FreeNode
>>> >         norBIT Gesellschaft fuer Unternehmensberatung und
>>> >         Informationssysteme mbH
>>> >         Rheinstrasse 13, 26506 Norden
>>> >         GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>> >         _______________________________________________
>>> >         Qgis-user mailing list
>>> >         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> >         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> >     This transmission is intended for the named addressee(s) only and
>>> >     may contain sensitive or protectively marked material up to
>>> >     RESTRICTED and should be handled accordingly. Unless you are the
>>> >     named addressee (or authorised to receive it for the addressee) you
>>> >     may not copy or use it, or disclose it to anyone else. If you have
>>> >     received this transmission in error please notify the sender
>>> >     immediately. All email traffic sent to or from us, including
>>> without
>>> >     limitation all GCSX traffic, may be subject to recording and/or
>>> >     monitoring in accordance with relevant legislation.
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140226/ffa820a5/attachment.html>
