[Qgis-user] Run-time error R6034
James Wood jwood911 at gmail.com
Thu Feb 27 06:11:11 PST 2014
Just wanted to comment that I installed x64 2.2 via OSGeo4W (this was after Jürgen promoted the packages again around the 23rd) and do not have any issues on startup. I'm running Windows 7 SP1. I previously had 2.0.1 loaded that also ran without any issues. As suggested before, there are probably conflicting DLLs that need to be resolved.
 Best Regards,James
Date: Thu, 27 Feb 2014 06:32:18 +0000
To: tijan49 at yahoo.fr
CC: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Run-time error R6034
Think the next step is to test whether the 32-bit version exhibits this issue or not. Never had this problem with v1.8.
Still get the same issue if you go through OSgeo4W method. As I say, need to verify if it is just the 64 bit version or both!
Cheers
Lester
On 27 February 2014 05:56, Tijan49 <tijan49 at yahoo.fr> wrote:
    Hello,
      I have exactly the same bug, with apparently no more consequences
      later.
      Thanks,
      Jean
      Le 26/02/2014 23:58, Lester Anderson a écrit :
                Hello
                I have installed version 2.2 of QGIS from the
                stand-alone installer for Windows 64-bit and it is still
                giving the same run-time error that 2.0.1 did on
                starting the program. As before, this does not affect
                the program but clearly was not addressed:
              No idea what the program is trying to do, put it is on the
              start up phase where it is restoring loaded plugins.
            Still a bug to me.
          Cheers
        Lester
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140227/db1cd10e/attachment.html>
