[Qgis-user] Run-time error R6034
Nathan Woodrow
madmanwoo at gmail.com
Fri Feb 28 02:01:11 PST 2014
I did see it with 2.1 but haven't had it with 2.2 yet. Will do some more
testing.
- Nathan
On Fri, Feb 28, 2014 at 7:57 PM, Lester Anderson <arctica1963 at gmail.com>wrote:
> The fact that other users are finding the same issue with the 64-bit
> version indicates that there is a problem with the distribution, albeit
> very subtle, that is generating this non-fatal error. This was identical to
> the 2.0.1 release; as to, tracing the cause of the error that is
> problematic but one would infer a dll problem (somewhere).
> No such problems with the 32-bit version.
> Cheers
> Lester
> On 28 February 2014 07:44, Luca Lanteri <mescal72 at gmail.com> wrote:
>> I confirm that I have the same error with at least 5 PCs w/ windows 7 and
>> the 64 bit version of QGIS.
>> >L<
>> 2014-02-27 23:55 GMT+01:00 Lester Anderson <arctica1963 at gmail.com>:
>> Hello,
>>> Just to quickly report back and say that installing the 32-bit version
>>> of QGIS 2.2 is fine; no run-time error message. Clearly this appears to be
>>> an issue with the 64-bit one, but no idea why.
>>> Lester
>>> On 27 February 2014 14:16, Minoru Akagi <akaginch at gmail.com> wrote:
>>>> Hi,
>>>> I think it's not easy to find conflicted dll files, but providing
>>>> mini-dump file could be easy way to give useful resource to debug this
>>>> problem.
>>>> Steps to provide mini-dump file:
>>>> 1. Download Process Explorer. It's only 1.2 MB archived file. Unzip
>>>> and execute procexp.exe.
>>>> http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
>>>> 2. Run QGIS 2.2 64-bit
>>>> 3. After the R6034 error message is displayed (do not click OK
>>>> button), select qgis-bin.exe in the tree of Process Explorer,
>>>> right-click it and click "Create Minidump..." in the context menu.
>>>> Then specify output file path in the file dialog.
>>>> 4. Share the written qgis-bin.dmp file. It may be large (around 16MB),
>>>> so it's better to zip it and use storage service (e.g. Google Drive,
>>>> DropBox, etc).
>>>> Attached image is for visual.
>>>> Regards,
>>>> Minoru
>>>> howtodump.png<https://docs.google.com/file/d/0B-D5Y8MiZKrnd1hsVTA2c2Jodk1WQ3VtOWRDa0xLRVdzVHRB/edit?usp=drive_web>
>>>> 2014-02-27 21:59 GMT+09:00 Tijan49 <tijan49 at yahoo.fr>:
>>>> Hello Jurgen,
>>>>> Sorry for my ignorance, but how can I verify that no DLLs in system32
>>>>> are in conflict with Dlls shipped with qgis ;
>>>>> Thank you
>>>>> Jean
>>>>> Le 27/02/2014 09:02, Jürgen E. Fischer a écrit :
>>>>> Hi,
>>>>>> On Thu, 27. Feb 2014 at 06:32:18 +0000, Lester Anderson wrote:
>>>>>>> Think the next step is to test whether the 32-bit version exhibits
>>>>>>> this
>>>>>>> issue or not. Never had this problem with v1.8.
>>>>>>> Still get the same issue if you go through OSgeo4W method. As I say,
>>>>>>> need
>>>>>>> to verify if it is just the 64 bit version or both!
>>>>>> And verify that you don't have any DLLs in system32 that conflict with
>>>>>> DLLs shipped whit QGIS.
>>>>>> Jürgen
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140228/3969af04/attachment.html>
