[Qgis-user] Run-time error R6034
Lester Anderson
arctica1963 at gmail.com
Fri Feb 28 01:57:13 PST 2014
The fact that other users are finding the same issue with the 64-bit
version indicates that there is a problem with the distribution, albeit
very subtle, that is generating this non-fatal error. This was identical to
the 2.0.1 release; as to, tracing the cause of the error that is
problematic but one would infer a dll problem (somewhere).
No such problems with the 32-bit version.
Cheers
Lester
On 28 February 2014 07:44, Luca Lanteri <mescal72 at gmail.com> wrote:
> I confirm that I have the same error with at least 5 PCs w/ windows 7 and
> the 64 bit version of QGIS.
> >L<
> 2014-02-27 23:55 GMT+01:00 Lester Anderson <arctica1963 at gmail.com>:
> Hello,
>> Just to quickly report back and say that installing the 32-bit version of
>> QGIS 2.2 is fine; no run-time error message. Clearly this appears to be an
>> issue with the 64-bit one, but no idea why.
>> Lester
>> On 27 February 2014 14:16, Minoru Akagi <akaginch at gmail.com> wrote:
>>> Hi,
>>> I think it's not easy to find conflicted dll files, but providing
>>> mini-dump file could be easy way to give useful resource to debug this
>>> problem.
>>> Steps to provide mini-dump file:
>>> 1. Download Process Explorer. It's only 1.2 MB archived file. Unzip
>>> and execute procexp.exe.
>>> http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
>>> 2. Run QGIS 2.2 64-bit
>>> 3. After the R6034 error message is displayed (do not click OK
>>> button), select qgis-bin.exe in the tree of Process Explorer,
>>> right-click it and click "Create Minidump..." in the context menu.
>>> Then specify output file path in the file dialog.
>>> 4. Share the written qgis-bin.dmp file. It may be large (around 16MB),
>>> so it's better to zip it and use storage service (e.g. Google Drive,
>>> DropBox, etc).
>>> Attached image is for visual.
>>> Regards,
>>> Minoru
>>> howtodump.png<https://docs.google.com/file/d/0B-D5Y8MiZKrnd1hsVTA2c2Jodk1WQ3VtOWRDa0xLRVdzVHRB/edit?usp=drive_web>
>>> 2014-02-27 21:59 GMT+09:00 Tijan49 <tijan49 at yahoo.fr>:
>>> Hello Jurgen,
>>>> Sorry for my ignorance, but how can I verify that no DLLs in system32
>>>> are in conflict with Dlls shipped with qgis ;
>>>> Thank you
>>>> Jean
>>>> Le 27/02/2014 09:02, Jürgen E. Fischer a écrit :
>>>> Hi,
>>>>> On Thu, 27. Feb 2014 at 06:32:18 +0000, Lester Anderson wrote:
>>>>>> Think the next step is to test whether the 32-bit version exhibits
>>>>>> this
>>>>>> issue or not. Never had this problem with v1.8.
>>>>>> Still get the same issue if you go through OSgeo4W method. As I say,
>>>>>> need
>>>>>> to verify if it is just the 64 bit version or both!
>>>>> And verify that you don't have any DLLs in system32 that conflict with
>>>>> DLLs shipped whit QGIS.
>>>>> Jürgen
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140228/2f09552a/attachment.html>
