[Qgis-user] Run-time error R6034
Luca Lanteri mescal72 at gmail.com
Thu Feb 27 23:44:18 PST 2014
I confirm that I have the same error with at least 5 PCs w/ windows 7 and
the 64 bit version of QGIS.
>L<
2014-02-27 23:55 GMT+01:00 Lester Anderson <arctica1963 at gmail.com>:
> Hello,
> Just to quickly report back and say that installing the 32-bit version of
> QGIS 2.2 is fine; no run-time error message. Clearly this appears to be an
> issue with the 64-bit one, but no idea why.
> Lester
> On 27 February 2014 14:16, Minoru Akagi <akaginch at gmail.com> wrote:
>> Hi,
>> I think it's not easy to find conflicted dll files, but providing
>> mini-dump file could be easy way to give useful resource to debug this
>> problem.
>> Steps to provide mini-dump file:
>> 1. Download Process Explorer. It's only 1.2 MB archived file. Unzip
>> and execute procexp.exe.
>> http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
>> 2. Run QGIS 2.2 64-bit
>> 3. After the R6034 error message is displayed (do not click OK
>> button), select qgis-bin.exe in the tree of Process Explorer,
>> right-click it and click "Create Minidump..." in the context menu.
>> Then specify output file path in the file dialog.
>> 4. Share the written qgis-bin.dmp file. It may be large (around 16MB),
>> so it's better to zip it and use storage service (e.g. Google Drive,
>> DropBox, etc).
>> Attached image is for visual.
>> Regards,
>> Minoru
>>  howtodump.png<https://docs.google.com/file/d/0B-D5Y8MiZKrnd1hsVTA2c2Jodk1WQ3VtOWRDa0xLRVdzVHRB/edit?usp=drive_web>
>> 2014-02-27 21:59 GMT+09:00 Tijan49 <tijan49 at yahoo.fr>:
>> Hello Jurgen,
>>> Sorry for my ignorance, but how can I verify that no DLLs in system32
>>> are in conflict with Dlls shipped with qgis ;
>>> Thank you
>>> Jean
>>> Le 27/02/2014 09:02, Jürgen E. Fischer a écrit :
>>>  Hi,
>>>> On Thu, 27. Feb 2014 at 06:32:18 +0000, Lester Anderson wrote:
>>>>> Think the next step is to test whether the 32-bit version exhibits this
>>>>> issue or not. Never had this problem with v1.8.
>>>>> Still get the same issue if you go through OSgeo4W method. As I say,
>>>>> need
>>>>> to verify if it is just the 64 bit version or both!
>>>> And verify that you don't have any DLLs in system32 that conflict with
>>>> DLLs shipped whit QGIS.
>>>> Jürgen
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140228/7c4c4d5e/attachment.html>
