[Qgis-user] Run-time error R6034
Lester Anderson arctica1963 at gmail.com
Thu Feb 27 14:55:00 PST 2014
Hello,
Just to quickly report back and say that installing the 32-bit version of
QGIS 2.2 is fine; no run-time error message. Clearly this appears to be an
issue with the 64-bit one, but no idea why.
Lester
On 27 February 2014 14:16, Minoru Akagi <akaginch at gmail.com> wrote:
> Hi,
> I think it's not easy to find conflicted dll files, but providing
> mini-dump file could be easy way to give useful resource to debug this
> problem.
> Steps to provide mini-dump file:
> 1. Download Process Explorer. It's only 1.2 MB archived file. Unzip
> and execute procexp.exe.
> http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
> 2. Run QGIS 2.2 64-bit
> 3. After the R6034 error message is displayed (do not click OK
> button), select qgis-bin.exe in the tree of Process Explorer,
> right-click it and click "Create Minidump..." in the context menu.
> Then specify output file path in the file dialog.
> 4. Share the written qgis-bin.dmp file. It may be large (around 16MB),
> so it's better to zip it and use storage service (e.g. Google Drive,
> DropBox, etc).
> Attached image is for visual.
> Regards,
> Minoru
>  howtodump.png<https://docs.google.com/file/d/0B-D5Y8MiZKrnd1hsVTA2c2Jodk1WQ3VtOWRDa0xLRVdzVHRB/edit?usp=drive_web>
> 2014-02-27 21:59 GMT+09:00 Tijan49 <tijan49 at yahoo.fr>:
> Hello Jurgen,
>> Sorry for my ignorance, but how can I verify that no DLLs in system32 are
>> in conflict with Dlls shipped with qgis ;
>> Thank you
>> Jean
>> Le 27/02/2014 09:02, Jürgen E. Fischer a écrit :
>>  Hi,
>>> On Thu, 27. Feb 2014 at 06:32:18 +0000, Lester Anderson wrote:
>>>> Think the next step is to test whether the 32-bit version exhibits this
>>>> issue or not. Never had this problem with v1.8.
>>>> Still get the same issue if you go through OSgeo4W method. As I say,
>>>> need
>>>> to verify if it is just the 64 bit version or both!
>>> And verify that you don't have any DLLs in system32 that conflict with
>>> DLLs shipped whit QGIS.
>>> Jürgen
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140227/4a01e777/attachment.html>
