[Qgis-user] Shifting overlapping points
Alexander Bruy
alexander.bruy at gmail.com
Mon Jan 6 04:52:09 PST 2014
Hi Martin,
2014/1/6 Martin Gibson <martin at creativeinterpretation.co.uk>:
> Hi,
> I'm more familiar with ArcGIS than QGIS but starting to shift over to using
> QGIS for most/all work. One thing I had been using QGIS for anyway was
> shifting overlaid points, as I couldn't get Arc to do this. I was using the
> ShiftPoints plugin, but it doesn't appear to be available for 2.0 - I have
> come across a statement that it obsolete now and that I should use Sextante
> instead. Can't find any info on how to achieve what I used to with the
> plugin - can anyone help?
ShiftPoints plugin now not supported as its functionality already
available via Processing (Analysis menu). You can find this algorithm
in the Processing toolbox under QGIS Geoalgorithms → Vector
geometry tools → Point displacement.
Alternatively you can use search box in the top of Procesing toolbox
and type something like "disp". List of algorithms will be filtered to
match your query.
Hope this helps
Alexander Bruy
