[Qgis-user] item ID/UUID feature in print composer
Andreas Neumann
a.neumann at carto.net
Wed Jan 29 05:29:13 PST 2014
Hi Otto,
The ItemID is used for QGIS Server and any potential web client. You can
set an ID on an item (e.g. a map and a label) and then the web client
can send properties to set a property (e.g. label text) for that
specific item.
The GetProjectSettings command lists what items which IDs are available
in a layout.
The UUID I think is use internally by QGIS - but I am not sure about
that and who introduced it.
Andreas
Am 29.01.2014 13:21, schrieb Otto Dassau:
> Hi,
> I would like to describe the item ID feature in the print composer a little
> better in the manual. All we have is "With the Item ID you can create a
> relationship to the other print composer items." and I don't really know
> what this feature can be used for.
> Can someone explain and maybe give an example, where the item ID and
> UUID can be used and are usually for?
> Thanks a lot
> Otto
> Qgis-user mailing list
