[Qgis-user] Shapefile not visible when zoom in - Linux
D'Eramo, Massimo massimo.deramo at garmin.com
Fri Jun 13 07:50:59 PDT 2014
Hi all,
first post to the list for me... hope to not repeat already solved issues.
I'm using v2.2 on Mint Linux 13, but when I load a shapefile and try to zoom in, the data disappears from screen. Zooming back out makes data appears again, this happens at a scale of about 1:300.00. This happens with all kind of shapefiles: points - lines - area. Moreover, I'm not able to use the element information tool: clicking on an object does not shows any information window. Rasters are indeed visible without any issue at any zoom level.
I never experienced such issues on all Windows system I use at work, while at home I try and use all open-source systems. Are these issues related to something wrong in configuration or is it a bug?
Thanks in advance
Massimo D'Eramo
CONFIDENTIALITY NOTICE: This email and any attachments are for the sole use of the intended recipient(s) and contain information that may be confidential and/or legally privileged. If you have received this email in error, please notify the sender by reply email and delete the message. Any disclosure, copying, distribution or use of this communication (including attachments) by someone other than the intended recipient is prohibited. Thank you.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140613/aaeed644/attachment.html>
