[Qgis-user] Help for QGIS-Web-Client
Bernhard Ströbl bernhard.stroebl at jena.de
Mon May 12 07:54:03 PDT 2014
Hi Amandine,
hmm, the GetMap request lacks some parameters: WIDHT HEIGHT BBOX CRS ;
not sure if they are optional, I doubt it though, because they tell the
server the size of the image you request (WIDHT, HEIGHT) the part of the
world you want to see (BBOX) and the projection the map should be in (CRS)
Use QGIS desktop to request maps, leave just _one_ layer in your
server's project and try to get a map from that in a first step.
You must have QGIS server running without errors prior to QWC!
Bernhard
Am 12.05.2014 15:31, schrieb Amandine SCHLOUPT:
> I have "500 Internal Server Error" on a GetMap request
> ("http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/var/www/qgis-web-client/projects/agriculture.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=adm_lorraine_bdt&FORMAT=image/png"):
> /Internal Server Error/
> /The server encountered an internal error or misconfiguration and was
> unable to complete your request./
> /Please contact the server administrator, webmaster at localhost and inform
> them of the time the error occurred, and anything you might have done
> that may have caused the error./
> /More information about this error may be available in the server error
> log./
> I don't know how to do in QGIS desktop...
> When I run QWC, I get an error with firebug :
> "TypeError: y is null
> ...;if(a.getMonth()==G.getMonth()&&a.getFullYear()==G.getFullYear()){this.cells.rem..."
> The CRS of the project is defined : 2154. I don't understand "QWC match?".
Define the same CRS in GlobalOptions.js
> Thanks!
> *Amandine *
> *De: *"Bernhard Ströbl" <bernhard.stroebl at jena.de>
> *À: *"Amandine SCHLOUPT" <aschloupt at aguram.org>
> *Cc: *qgis-user at lists.osgeo.org
> *Envoyé: *Lundi 12 Mai 2014 14:10:30
> *Objet: *Re: [Qgis-user] Help for QGIS-Web-Client
> Well,
> QWC obviously reads GetCapabilities (or GetProjectSettings) otherwise
> the layer tree would not show any layers. Do you get a response on a
> GetMap request (either in your browser or in QGIS desktop)?
> If you use mozilla install firebug and check which script hangs (and
> where). Just a guess: do the CRS of the project and QWC match?
> Bernhard
> Am 12.05.2014 14:04, schrieb Amandine SCHLOUPT:
>  > My QGIS-project is configured (project, setting OWS-Server) and I have a
>  > QGIS 2.2.
>  > I tested again QGIS Server WMS and I have :
>  > But, on QGIS-Web-Client, my QGIS-projects always tries to load the
> map....
>  > Thanks
>  > *Amandine
>  > *Envoyé: *Lundi 12 Mai 2014 12:30:26
>  > Hi,
>  > have you configured your QGIS-project with the same version you run on
>  > the server (especially project-settings OWS-Server)?
>  > If you have a QGIS 1.8 project file and try to run it with QGIS 2.x on
>  > the server you will get problems.
>  > Bernhard
>  > Am 12.05.2014 12:14, schrieb Amandine SCHLOUPT:
>  >  > I think that problem is QGIS-Server, or maybe apache2?
>  >  > Result with GetCapabilities
> (http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities)
>  >  > : /"text/xml image/jpeg image/png image/png; mode=16bit image/png;
>  >  > mode=8bit image/png; mode=1bit text/plain text/html text/xml
>  >  > application/vnd.ogc.gml application/vnd.ogc.gml/3.1.1 image/jpeg
>  >  > image/png text/xml svg png pdf text/xml wfslayer//"/.
>  >  > With QGIS Desktop (URL =
>  >  > http://192.168.0.232/cgi-bin/qgis_mapserv.fcgi?), I have :
>  >  > Thanks!
>  >  > *Amandine
>  >  > *À: *qgis-user at lists.osgeo.org
>  >  > *Envoyé: *Lundi 12 Mai 2014 09:17:00
>  >  > Hi Amandine,
>  >  > it is hard to tell what is going wrong. Please be more precise. Is
> it a
>  >  > QGIS-Server or QGIS-web-client (QWC) problem? How to detect:
>  >  > Can you connect to the server (GetCapabilities) and receive maps
>  >  > (GetMap) with another client (e.g. your browser, QGIS desktop)?
>  >  > What are you doing and what happens?
>  >  > Bernhard
>  >  > Am 12.05.2014 09:07, schrieb Amandine SCHLOUPT:
>  >  >  > Hi all,
>  >  >  > I have an Ubuntu precise 12.04.3 LTS.
>  >  >  > I would like to update QGIS-Web-Client :
>  >  >  >   * I have updated QGIS
>  > (http://www.qgis.org/fr/site/forusers/alldownloads.html#ubuntu) like
>  >  >  >     this : apt-get install qgis python-qgis. It's OK.
>  >  >  >   * Then, I have updated QGIS Server
>  > (http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial)
>  >  >  >     with : apt-get install qgis-mapserver libapache2-mod-fcgid.
>  > It's OK.
>  >  >  >   * Finally, I have updated apache2
>  >  >  >     (https://github.com/qgis/qgis-web-client) like this : apt-get
>  >  >  >     install apache2 libapache2-mod-fcgid. It's OK.
>  >  >  > I have installed QGIS-Web-Client again and my map's projects
> are not
>  >  >  > loaded...
>  >  >  > I have tried with old version of QGIS-Web-Client (which is already
>  >  >  > installed), and my projects are still not loaded.
>  >  >  > Have you encountered this problem?
>  >  >  > I think QGIS-Web-Client didn't appreciate the updateof apache2 or
>  >  >  > Thank you!
>  >  >  > HTH,
>  >  >  > *Amandine SCHLOUPT
__________ Information from ESET Mail Security, version of virus signature database 9789 (20140512) __________
The message was checked by ESET Mail Security.
http://www.eset.com
