[Qgis-user] Importing open street map .osm files
Alexandre Neto senhor.neto at gmail.com
Tue May 27 00:43:44 PDT 2014
Also, there seems to be a bug in the  first phase, as QGIS does not
download all the elements in the selected extent.
https://hub.qgis.org/issues/8878
The workaround is to download the .osm files using the export button on
www.openstreetmap.org
Best Regards,
Alexandre Neto
Em 27/05/2014 08:29, "G. Allegri" <giohappy at gmail.com> escreveu:
> I think the docs are a bit misleading. I think it should be said that when
> importing the XML topology a Spatialite is created *but with no geometry
> layers*. They will be ctreated only in the third phase.
> The fact that the second phase (XML import) asks if you want to create a
> connection confuses the user, because if he opens the connection it won't
> see any layer.
> I think I will open a ticket to suggest to make the docs more clear.
> giovanni
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/5079a9c9/attachment.html>
