[Qgis-user] Importing open street map .osm files
Andre Joost andre+joost at nurfuerspam.de
Tue May 27 08:16:59 PDT 2014
Am 27.05.2014 10:22, schrieb G. Allegri:
> Mmm, this is strange. I've had some problems with lines missed during the
> Spatialite lines creation (third phase) but never with missing lines from
> the Overpass API, which is what the plugin uses to download data.
> This also happens for the test area used for the issue.
A line might be missing if you did not laod all nodes that are part of
the line. This is configurable with the Overpass API, but you have no
control on it with the OSM plugin or the direct export function on the
webpage.
HTH,
André Joost
