[Qgis-user] zoomtopoint.py
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Sep 2 00:41:38 PDT 2014
Vincent Schut <schut at ...> writes:
> Hi Mike,
> I'm not familiar with this zoomtopoint.py, however, your coordinates do
> not seem to match your projection. EPSG 4326 is geographic lon, lat in
> degrees, so its range is from -180 to 180 (x) and -90 to 90 (y). The
> numbers you put as X and Y seem more appropriate for a meters based
> projection. Maybe try some real coordinates in degrees, or change your
> projection...
You can familiarize yourself with the script by reading the link
http://www.qgis.nl/2014/07/10/qgis-processing-scripts-gebruiken/?lang=en
that was a little bit farther in the question.
-Jukka Rahkonen-
> Best regards,
> Vincent.
