[Qgis-user] How to Make a project layer editable
Randal Hale rjhale at northrivergeographic.com
Thu Sep 25 13:54:41 PDT 2014
To be honest - I'm not sure if ArcGIS will edit coverages any more (just
checked). It will convert to and from but I didn't see anything that
indicated edit.
I think your best bet is to convert it to a shapefile (or
postgis/spatialite) if possible. If memory serves me right you could
store a mix of geometry in a coverage so watch as you are converting.
Randy
On 09/25/2014 03:56 PM, Richard Duivenvoorde wrote:
> On 25-09-14 19:04, Tom Lennon wrote:
>> I have a project with layers imported from Arc Info Coverages
>> (directories). They all appear to be locked from editing. If I select a
>> polygon, list the attributes, and attempt to change them the pencil
>> toggle in not active and no new values can be entered. I have tried
>> other projects which were not imported from Arc and they are editable,
>> so the problem seems to be import layer related.
> Hi Tom,
> QGIS uses the OGR library to read and (optionally) write certain data
> formats. See this table:
> http://www.gdal.org/ogr_formats.html
> As you can read here:
> http://www.gdal.org/drv_avcbin.html
> and
> http://www.gdal.org/drv_avce00.html
> this format is read only for OGR, meaning it is also read-only for QGIS.
> If you save this in another format (eg shapefile, or put it in Postgis)
> then you can edit it.
> But you will need Esri software to write that back to coverages I think ...
> Regards,
> Qgis-user mailing list
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
