[Qgis-user] Connect Qgis 2.4 to Oracle (SDE)
Stéphane Henriod
s at henriod.info
Tue Sep 30 00:16:37 PDT 2014
Hi again
I have moved a little bit forward and I have edited the file tnsnames.ora
located under C:\OraClient11g\product\11.2.0\client_1\NETWORK\ADMIN:
name_of_my_db =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = *********)(PORT = 1568))
(CONNECT_DATA =
(SERVICE_NAME = name_of_my_db)
Will Qgis read this file or does it require its own copy of it? If yes,
where should it be located? If no, how does it know where tnsnames.ora is
stored? Should there be an entry in the registry?
By the way, my sqlnet.ora file (also located in
C:\OraClient11g\product\11.2.0\client_1\NETWORK\ADMIN) looks like this:
# sqlnet.ora Network Configuration File:
C:\oracle\product\10.2.0\NETWORK\ADMIN\sqlnet.ora
# Generated by Oracle configuration tools.
# Filename......: sqlnet.ora
# Name..........: $Id: sqlnet.ora,v 1.3 2004/11/22 13:47:17 oracle Exp $
# Date..........: $Source:
/data/repository/cvsroot/ORACLE/env_sqlnet/indus/sqlnet.ora,v $
SQLNET.AUTHENTICATION_SERVICES= (NTS)
NAMES.DIRECTORY_PATH= (LDAP,TNSNAMES,ONAMES)
SQLNET.CRYPTO_SEED = "************************"
NAMES.PREFERRED_SERVERS =
(ADDRESS_LIST =
(ADDRESS = (COMMUNITY = ************************)(PROTOCOL = TCP)(Host
= ************************)(Port = 1568))
= ************************)(Port = 1529))
= ************************)(Port = 1527))
= ************************)(Port = 1528))
NAMES.DEFAULT_DOMAIN = ************************
SQLNET.EXPIRE_TIME = 0
Thanks a lot in advance!
Stéphane
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"Si les contacts avec les étrangers lui étaient permis, [le citoyen
ordinaire] découvrirait que ce sont des créatures semblables à lui-même et
que la plus grande partie de ce qu'on lui a raconté d'eux est fausse. Le
monde fermé, scellé, dans lequel il vit, serait brisé, et la crainte, la
haine, la certitude de son bon droit, desquelles dépend sa morale,
pourraient disparaître" -- George Orwell ("1984")
Photos de voyages, photos de montagne: http://www.henriod.info
2014-09-30 7:47 GMT+02:00 Stéphane Henriod <s at henriod.info>:
> Hi all
> I want to connect Qgis 2.4 to an Oracle DB (with SDE) but I always get
> connection errors.
> I have tried many different options from within the window *Create a new
> Oracle Connection* but I always get an error message (*ORA-12514:
> TNS:listener does not currently know of service requested in connect
> descriptor* or similar messages). I know however that the DB is working
> and listening. I know the correct host, the correct port and I have valid
> username / password.
> The IT support here gave me 2 (independent) pieces of advice but I'm not
> sure how to implement them with Qgis:
> - "Does your client (Qgis) know about the correct *tns_admin*
> directory?"
> - "Make sure that LDAP is listed first: NAMES.DIRECTORY_PATH = (LDAP,
> TNSNAMES,ONAMES)"
> Anyone has an idea?
> Stéphane
> PS: this question has also been posted here:
> http://gis.stackexchange.com/questions/115534/qgis-how-setup-ldap-as-default-to-resolve-a-connection-to-oracle
> but unsuccessfully so far
> malheureux" -- Albert Einstein
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140930/127b3bac/attachment.html>
