[Qgis-user] QGIS - Graphic Design Workflow
Andreas Neumann a.neumann at carto.net
Thu Dec 3 21:23:20 PST 2015
Hi Ezra,
Yes - "bringing in SVG files", it means bringing them in with "Add
Image". But note, although it says image - they are still a fully
scalable vector graphic without any quality degradation.
Gradients: this is perfectly possible within the QGIS print composer.
You can use any fill that you can do in the main map canvas, also in the
print composer: vector pattern fills, raster pattern fills, gradients,
shapeburst, simple fill, etc. - but it is limited to the page background
or basic shapes. A future version of the print composer may also add a
path tool.
There is no doubt that a vector graphics editor, such as
Inkscape/Illustrator/Corel offers more possibilities than QGIS - but the
difference isn't that huge.
Embedding Inkscape in QGIS: not very feasible. It is uses completely
different libraries than QGIS and the dependency would be too huge. It
would be more feasible to integrate something like
http://svg-edit.googlecode.com/svn-history/r1771/trunk/editor/svg-editor.html
to edit vector graphics. This could be done with the Webkit/blink component.
Andreas
On 04.12.2015 06:06, Ezra Boyd wrote:
> Andreas,
> Thanks for the suggestion.
> Just one quick clarification, when you say "You can bring in SVG
> files" do you mean bring them in as a template or bring them in using
> "Add Image"?
> I've found that  the Print Composer work's great for many of my
> purposes.  There are certain things that Inkscape can do -- such as
> gradient backgrounds and embolded text.  On the one hand more of this
> would be nice in Print Composer, but on the other hand that's what
> Inkscape is for.  Just thinking off the top of my head, but would it
> be feasible to integrate Inkscape into QGIS similar to how GRASS &
> SAGA are integrated?
> Thanks Again,
> Ezra
> Ezra Boyd, PhD
> DisasterMap.net, LLC <http://DisasterMap.net>
> ezgis <mailto:ezgis76 at gmail.com>76 at gmail.com <mailto:ezgis76 at gmail.com>
> (504)533-4447
> *_
> _*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151204/7f56556c/attachment.html>
