[Qgis-user] Label outlines.
Nathan Woodrow
madmanwoo at gmail.com
Tue Dec 15 13:21:46 PST 2015
Bob,
QGIS has had buffer options on the labels for a while now. Just add a
buffer with the colour you want for the outline is all you need. No need
to copy the data or anything like that.
Nathan
On Wed, 16 Dec 2015 6:00 am Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> All,
> Any option in QGIS for outlining Labels? I’ve sort of got a trick working
> by adding a layer twice (see side note below). This isn’t good for long
> term editing of the data files (I have to edit both SHP files, or edit one,
> and copy to the new name again. Hmm, on Linux, does QGIS follow soft links
> correctly?
> SIDENOTE: Why do I need to copy a SHP file to a new name in order to use
> the same data file but with different styling. I would have figured I
> could rename the layer in QGIS and then add the same datafile again, but
> alas, it gets mixed up when the same data file is used more than once. I
> stacked the same layer on top of itself but with a slightly large text size
> on the bottom (background) in order to display a colored outline of the
> Label/Text.
> Thanks
> bobb
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151215/303ef7b8/attachment.html>
