[Qgis-user] Label outlines.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Dec 15 13:31:58 PST 2015
Nathan and Goyo,
Buffer worked perfect. My problem was using fifteen other application that call that an “outline"
Another one for you both. How do I set "map units" as a default in all the Dialogs instead of “mm"??
bobb
On Dec 15, 2015, at 3:21 PM, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Bob,
QGIS has had buffer options on the labels for a while now. Just add a buffer with the colour you want for the outline is all you need. No need to copy the data or anything like that.
Nathan
On Wed, 16 Dec 2015 6:00 am Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
All,
Any option in QGIS for outlining Labels? I’ve sort of got a trick working by adding a layer twice (see side note below). This isn’t good for long term editing of the data files (I have to edit both SHP files, or edit one, and copy to the new name again. Hmm, on Linux, does QGIS follow soft links correctly?
SIDENOTE: Why do I need to copy a SHP file to a new name in order to use the same data file but with different styling. I would have figured I could rename the layer in QGIS and then add the same datafile again, but alas, it gets mixed up when the same data file is used more than once. I stacked the same layer on top of itself but with a slightly large text size on the bottom (background) in order to display a colored outline of the Label/Text.
Thanks
bobb
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151215/fe51a9de/attachment.html>
