[Qgis-user] Looking for a suggestion on a vector format
Jesse McGraw
jlmcgraw at gmail.com
Fri Dec 18 06:14:30 PST 2015
All,
Before I go too far down the wrong path perhaps you can help me with
a suggestion on a vector format to use for a project of mine:
I'm to looking to basically re-create various Instrument Approach
Procedure plates (see here
<http://aeronav.faa.gov/d-tpp/1513/00375il28r.pdf> for an example for
San Francisco International - SFO ) from a database via a perl script
and display a number of them as vector overlays in an existing QGIS project
What would be a good format to use for this purpose?
I'm imagining something like a QGIS project file, but I want it to
contain to contain all of the various bits of information internally
(coordinates, names, styling, icons etc.) and not have to query anything
external so each file is a stand-alone unit.
Ideally all of the coordinates would be real world lon/lat so no
transformation would be required. Bonus points if the format is openly
standardized and easy to work with
DWG/DXF? SVG?
Thanks,
Jesse
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151218/691d30a2/attachment.html>
